Adding cruise control to F250 2009
no cable on the throttle... drive by wire.
Just need a new wheel with the cruise buttons, switch them out, and move your airbag module over... I believe you will need a new steering wheel bolt... for some reason I'm thinking you can't reuse it.
Once the buttons are there, if it doesn't work have the dealer turn the cruise control in your PCM to 'on'
There is no "horn only" anymore since there are airbags, too. I'm not sure about '07 and earlier, but in 2008 and later, there is only one clockspring listed regardless of the steering wheel.
IIRC, the horn only ones don't have all the wires needed for cruise.
Email Ed the parts guy and ask him what parts you need he can most likly get you a deal on them to. parts@y2kford.com
as long as you have the drive by wire set up, you need a steering wheel and a cruise control switch and reprogram the PCM.
to many diff steering wheels in catalog to post up all the part numbers, but a plain jane steering wheel is AC3Z3600BE and switchs 6L2Z9C888CAA LH, 6L2Z9C888EAA RH w/o redundant controls.
flippflopmann
1999 to 2016 Super Duty
11-22-2014 06:00 PM
