HID light on 2007
Those retrofitted ebay type HID setups are illegal. They are not a good idea anyway. The headlight housing and lense was designed for the halogen bulb that is in it. The HID bulb is positioned in the housing differently. It will produce excessive glare to oncomming vehicles.
Please don't be one more person that puts that blinding crap on their vehicle. I also wouldn't want another reason to get pulled over because of having illegal lights.
The correct way to convert to HID is to run a complete setup with housing lense and all.
Also stay away from the tinted blue bulbs etc like Silverstar. They actually prduce less light than clear bulbs, its just whiter.
If you want better headlights, get a head light relay kit that will provide more current to the bulbs and run some brighter bulbs like Sylvania Xtravision, GE Nighthawk, Phillips Vision Plus etc. They are +30% or +50% bulbs that run at the same wattage as the stock bulbs. Do not run increased wattage bulbs. They will run hotter.
HIDs make
I installed HIDs one yaer ago. They are exelent.
I got conversion kit for $250 installed. Make sure you buy Dual Beam Design (H13 bulbs). In the past if you wanted to convert to High Intensity Discharge technology you had to sacrifice your high beams. But not anymore! This HID Kit utilizes electromagnetic servo technology that is integrated right into the bulb holder to re-aim the headlight bulb up or down to switch between high and low beams.
Mine are very close to what a factory Hid look like and have had no complaints. On the Ford you will need to lower the aiming screw down slightly not to blind other drivers. They work really well visually in bad weather conditions. As for the fogs its strictly for off road use.
I don't agree. I encounter those retrofit kits at least 10 times a week and it makes it you can't see anything else on the road except for the vehicle that has them. They are illegal for a reason.
I think that HID should never have been used on any automobile period. I don't like its false colors either. I think its just trendy bling.
I don't know why so many people complain about the stock headlights. It wasn't that many years ago that headlights were far worse and people did fine with them.
What some of you guys may not know is that with all the bright light in front of you, your peripheral night vision is actually reduced, because your pupils on not dialated.
I like the fact that Hid's were available for me to have on my truck. You make some valid claims and I agree there is a large amount of crappy systems out there that tend to be different colors. Also those people you encounter on the road probably slaps those items in there without any care or adjustment to them. Then again you can get the same thing, when you install a new headlight and not adjust it. anyone that puts these on their trucks need to have little sense for other drivers on the road.
Also just my 02
umm....well i'd like to have brighter lights, that i know. my wifes the expy most of the time and she has a hard time with them. we had a 2009 santa fe that had kick *** lights on it. what's this "headlight relay kit" mentioned earlier?
if i wanted to go with the HID's, is this something i could do at home or should i call the dealer?
I hate all HID's with a passion. Factory or Bubba's Conversion kit. I had PRK Eye Surgery 2 yrs ago and now have 20/15 vision. At night I can see perfectly except when some damn fool with his $50 HID conversion comes along.
Then I see spots for minutes. Halogen bulbs don't affect me at all. Even properly designed factory HID's are excessively bright.
Well....that is a matter of opinion. Yours.. ....
Are we referring to aftermarket kits or just all Hid's in general?
So true, but with advances in the automotive world...so did the headlights. More and more automakers German, Japanese, American and so forth are applying it on their line up. It was one of the reasons for my decision to get it. I wanted something that was close to a factory look and the second thing was jumping out my cars with hid's to one that didn't was noted.
Did not know that
Also just my 02
Did not know that
Also just my 02
I meant HID of any kind should never have made its way to the automotive industry. Even the HID on the high end cars glares more than regular lights. I also don't like that HID produces false colors and when the light shines on different objects they do not reflect their normal color.
preach it brother.
Our 2003 Maxima has HID on the low beams, and I would actually like to convert that to halogen like the high beams. I don't like HID in bad weather and I don't like the beam cut off on the factory ones, because it doesn't allow any light to flood out past that point, so its only bright right in front of the car.
Thanks for the vote of confidence Buddy!
Isn't that being a hypocrite? You moan about cars with HID's yet you own one yourself. If you intend to really make a point sell your Maxima right away.
BTW what is a "false color" isn't every color a real color?
