1995 F350 2WD Dually Front Disk Brake Questions
Does anyone have a picture of the front disk brakes fully assembled on a 1995 F350 2WD dually? I took a set of brakes apart several weeks ago and I do not remember how the spring clips on the mounting bracket interface with the caliper. I believe they just sandwich between the mounting bracket and the caliper to keep the caliper from vibrating but I want to make sure. Also, when I disconnected the brake hose in order to install new calipers I found only one serrated washer which was between the hose block and the caliper on both sides. There was no washer between the bolt and the hose block. Is this normal? I always thought there was a washer at both places. The hose block and the caliper are also serrated.
Thanks,
Erv
Thanks,
Erv
michaelbrainardatwor
06-17-2011 04:11 AM
AKfordtruck
07-29-2010 01:49 PM
RexB
07-23-2002 12:30 AM
