Best place to get an injector wiring harness pigtails, and valve cover gaskets
i took my time when i did it and got the cheapest part i could be it from ford, powerstrokeshop.com or IH when i did mine. and then and got the part that they sold the cheapest from each place. i just did a quick search parts only from just ford around 320.....probably cheaper if you use IH for some..
my.02 only what is burnt or frayed is what needs to be replaced. if its still serviceable leave it be. a new one can fry just as easy as an old one.
its your money im out
I don't want to take anything away from OEM parts as I beleive you get what you pay for.
But you can go to NAPA, Advance, or Autozone etc and get the complete side (2 UVCH, 2 VCG, 2 pigtails) for around $75. Yes, this is Doorman, and I've seen first hand they are good quality.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
The early Doorman design from a few years ago, yes, some complaints.
Seems the new design is fine.
FWIW I have one of the Doorman Kits installed on my flow bench. I have easily gone through almost 2000 injectors, hooking up wires, unhooking wires almost a thousand times and the wiring, clips, gasket, everything still works perfectly fine.
I'm just saying is all...
__________________
here is a page I found some on at ebay.
1997 Ford F250 Superduty 7.3L Valve Cover Gasket - PAIR: eBay Motors (item 350357937887 end time Jun-22-10 10:36:42 PDT)
Thanks,
Paul
If I had to do the pigtails, I would remove the entire harness from the motor and cut the old ones off, twist the wires and solder the new ones one, covering the joint with shrink tubes. Best, permenant fix, IMO.
__________________
Injection valve cover harness and repair plug w/pigtails
Oreillys
Valve Cover Gasket Set #615-202 $75.99 ea x 2 = $151.98
Limited Lifetime Warranty DorMan-Brand
2ea required
List: Valve Cover Gasket Set - 1997 Ford F-250 | O'Reilly Auto Parts
Heating Element-Fuel Bowl #904-210 $50.99 1ea
Dorman 904-210 - Diesel Heating Element | O'Reilly Auto Parts
hey jim i was just about to post your site for him to reference too for the parts, who do you use for the pigtails and harness kits?
Rosewood Diesel Shop click performance parts and oem is at the top, cant miss it
#28
1997 F150 4.6
I am brand new to this but I have an issue I can't seem to find a solution, I had motors changed in my truck and it had a gas line leak which caused a fire and they never finished the truck,I brought it home and had to put a injector wiring harness on it. I had a relative help with it and there is one wire I can't find where it goes, the one goes to our pressure sponsor but the other wire coming off the harness beside it ,I cannlicate where it plugs in its only about 4in long off main harness by the oil sensor plug in. Any help will be a thankful.
#29
