Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- How to Flush Radiator
Step by step instructions for do-it-yourself repairs
Gooch's Radiator/Engine Backflush Procedure and Coolant Information
#271
I miss spoke and read your post as changing the T-stat. You dont have to change the sensor unless yours is bad. I never changed mine yet. Sorry about that. I would replace the T-stat housing with a billet aluminum one from Riffraff or dieselsite. The old stamped steel one will be all rusted inside.
Stamped steel? I can certainly imagine it might be rusty. I thought it was plastic. Need to pop my head under the hood.
Thanks my man.
#272
#274
http://www.riffraffdiesel.com/motorc...rmostat-96-03/
That's the only thermo I would recommend, personally. Unless you're running dual HPOS, in which case I would recommend the thermo Terminator Engineering sells.
Stewart
Stewart
#275
OAT Coolant test strips for your CAT EC-1 spec'd Heavy Duty Extended Life Coolant:
Stewart
You can still check the inhibitor package on a ELC, it is just a different test strip than the traditional DCA2 and DCA4 type test strips.
PEAK COMMERCIAL & INDUSTRIAL | FINAL CHARGE | EXTENDED LIFE COOLANT/ANTIFREEZE | AVAILABLE PRODUCTS
#276
I haven't seen this posted here before, so I am going to drop it in here for future readers of this thread:
elcfaq.pdf
Some great questions and answers from the people at CAT on ELC coolant, and it will help anyone to understand what it is and what it does differently.
elcfaq.pdf
#277
Coolant flush procedure specifics/clarification
Wealth of info in here... thanks to all.
I'm about to do a flush and I have a couple questions of clarification on the flush procedure:
When the "flush T" is inserted, is there a check valve in that? Which way are you pushing the water? Through the heater core and back into the pump, or back into the block?
I was building my own "flush T" including a heater shut off valve, and I was under the impression I could push the flush water toward the heater core, through it and into the water pump, through the radiator, through the engine and back out a second T in the heater hose from the block... I have a heater shut off valve between them so flush water only goes in that loop. would that work? Or am I not seeing this correctly. I think I would remove the thermostat so this loop includes the radiator and probably run the engine to get help from the water pump in circulating the flush water. But "back" flushing is mentioned -- does that mean you're pushing water back into the block through the heater hose, up through the radiator and...on your trucks out of the degas bottle? on my '95 it would have to disconnect the upper radiator hose. In that case does running the engine help, or do you do this just with water pressure and engine off?
For the distilled water flush, I took a 15 gallon sealed plastic drum, put a garden hose spigot at the bottom and an air quick connect at the top so I can pressurize it a little and push 15 gallons of distilled water through the engine.
I just need clarification on how the coolant/water should flow in order to flush effectively.
Also, I have an early '95 Powerstroke with the cap on the radiator and non-pressurized overflow bottle. I was also thinking I could flush water into the heater hose as discussed, and remove the thermostat and lower radiator hose... coolant flows top to bottom in the radiator, right? I'm just not sure where the coolant from the heater core goes when it enters the water pump...?? --to the radiator, then through the engine and back to flush T?
#278
Flush procedure clarification -early '95 DIT
Ok, Here's what I came up with after a few more minutes of thinking --based on logic and what I do know about the cooling system:
1. I can unhook the heater line at the water pump and flush just the heater core that way -- first, maybe, since some people have expressed concern about flushing heater core junk into the engine.
2. The heater core is in the loop with the engine and the water pump is always pumping, so there must be a bypass (and I sorta know this, too) at the thermostat so coolant can just circulate the engine and heater core when the coolant is still too cold open the thermostat. So If I leave the thermostat in, I can flush just the engine and heater core until it's clean.
3. If I take out the thermostat, the water pump and flush water pressure will push coolant through the whole system including the radiator to flush it out as well. Though, one thing I'm not clear on is whether the thermostat closes the bypass when it opens, and whether with the thermostat removed I'll be pushing some water through the radiator and some will bypass, thus limiting my radiator flush... But I'm not going to do this with the engine got. I hear that people have and didn't crack the heads or block or gasket, but I think pushing 40 to 50 degree water inside a hot engine is pushing my luck.
Let me know what y'all think. I'm still curious about the direction that Gooch is pushing the flush water in his instructions, or if there's no check valve in that T and he's pushing water both ways --likely to me from the looks of it. I would think that you wouldn't be able to or at least wouldn't want to push water backwards through the system while the engine's runnin, and I think I recall the engine running while the flush was being done in his writeup?
#279
#280
That's what I used when I did mine 4 gal of concentrate. If it was still low then I just kept adding concentrate till I was at the max line on the degaus bottle.
#281
#283
Thanks for the reply Roland!
I've got another question now:
Here's what going on:
I could only get the D-side block plug out so I can only get 6 gallon in when I refill I'm on my third flush. I still need to pull my old pump and put the new pump on, so I figured I'd put the new pump on with out the thermostat and do one last flush.
Here's the question:
If I can only get 6 gallons in and it's a 8 gallon system should put 1 gallon of distilled water in (after the last drain) then my 4 gallons of ELC then top off as needed with distilled water?
I know the answer is yes but I just want to confirm.
Thanks...Tom
Thanks...Tom
#284
on
I would first add the 4 gallons of concentrated ELC, then top off with the distilled water. This is still pretty much the same thing you are saying. You are just making sure that you can get all 4 gallons of antifreeze in before topping off. I usually mix up a little 50/50 to top it off after the initial fill up. I bought a case of 6 gallons when I did my first flush and change to ELC and had some left over for later.
#285
