Where should trailer plug be grounded to - 7-pin??
Trying to diagnose weak trailer brakes. I am at work right now, but when I get home I plan to check the grounds on both the RV and the truck. Can anyone tell me where the ground wires should go?
The ground on the truck will be the white wire from the plug. If you trace it back it will go about 2 ft in the harness and is bolted to the frame on the driver's side towards the rear.
As for the trailer, it can be anywhere so long as it is to the frame of the trailer.
