Can I use a 5.0 distributor with 5.8 - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 06-01-2010, 09:04 PM
torque head
torque head is offline
torque head is starting off with a positive reputation.
Thanks.... i noticed there a few people on here that have a wealth of info and you are diffidently one of them. People like me need people like you.. Look forward to talking to you about other issues.
Old 07-24-2017, 11:12 AM
Fordface48
Fordface48 is offline
Fordface48 is starting off with a positive reputation.
I am doing the same swap as mentioned in the post but I have a 89 5.8 that I'm putting in place of a 93 5.0 what all is needed for this swap
Old 07-26-2017, 06:12 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
I am assuming your using your 5.0 harness on the 5.8 motor being swapped in. you will need to find a 93 5.8 dizzy and get the cam gear pressed off, you will then have the 89 5.8 dizzy cam gear swapped over to the 93 5.8 dizzy. most any shop can do this.
this will make it plug N play on your current harness.
Old 07-26-2017, 06:32 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Or you could dismantle the 5.0 distributor you have, drill a hole/cut a slot in the 5.8 dizzy in the same place that the PIP harness comes through on your 5.0 distributor, and install the 5.0 PIP module in the 5.8 dizzy and reassemble it. I did the opposite mod to a 5.8 distributor one time.. worked great.
Three things are different between these two distributors..
- 89 dizzy has an onboard TFI module and the 93 uses a remote, that means the PIP module inside is connected differently.
- 5.0 motor has a roller cam while the 5.8 had a flat tappet(steel gear vs cast iron)
- 5.8 dizzy has larger journals and oilpump driveshaft than the 5.0 so these are not interchangable.
07CVPI79F302
11-23-2017 10:02 PM
ford300fan
17
09-28-2017 09:41 PM
Bluetorpedo
28
03-11-2017 08:50 PM
jdhudall
12-24-2016 09:28 PM
mrbillsadventures
11-02-2016 07:13 PM
Quick Reply: Can I use a 5.0 distributor with 5.8
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
