Lucas Girling Parking Brake chamber
Start here Lucas Girling - Haldex product category
There is a link for distributors on that page plus it looks like a lot of other good info on these brakes. You might also try a Ford dealer that deals in medium duty trucks and catch someone there who knows what these are.
I have the same problem HELP Please
I'm looking for some help on removing a lucas girling parking brake chamber on a mid 80's L8000. I'm trying to remove the wheel cylinder/expander that it's attached to in order to remove a broken brake line and have gotten stumped with this brake chamber. I was hoping to back off the large (2" or so) retaining nut and then it would come off. However that doesn't seem to happen. I can back this nut off about 5 turns or so, then it doesn't go any more. It appears that there are still threads there holding it to the wheel cylinder but it's like the nut bottoms out and doesn't want to turn any more. Anyone out there have any suggestions on this as this is my first time messing with this system?
Thanks
Thanks
I am having the very same problem with my 1986 F600 dump truck. Have you got it worked out? Please let me know how to do it if you have.
Thanks
Are you talking about the parking (spring brake) cylinder? If so, you HAVE to cage the spring! Be very careful messing with that 2" nut without caging. Cage by turning the nut that is pinned to the threaded rod on the back of the can and DO NOT USE an impact wrench to do so. It will be caged when there is 2" of threaded rod between the can and the bottom of the nut.
You only need to break loose the 2" nut, removing the "can" requires (in this sequence) caging, removing the bleeder fitting, removing the brake line (and plugging), removing the fitting the break line went into and then turning the can itself, the 2" nut is just a locknut, the can screws into the backing plate, not the nut.
It makes it easier to cage with the brake set to on, safer too as the engine needs to be running to turn them off and you don't need to be under there with it running.
These are designed to always be in the "on" state unless hydraulic pressure is applied, this way if something go's wrong with the hydro system and it loses pressure the brakes will go to the on state. There is a heavy spring inside the can trying to apply brake pressure 24/7, the hydro pressure overcomes the spring pressure when setting to off.
I use a cordless drill set to low speed but break it lose with a ratchet first, don't use an impact...no need and you could damage the threaded rod. Don't forget to chock the wheels too.
Broken caging spring :/
Has anyone had luck with this? I caged both my rear brakes one can spins loosely after backing off the 2" locking nut confirming the cage was correct but my other can is stiff.. tightened 2" back up the side that is acting caged trying to figure out the best option? Any advice would be greatly appreciated!
mytoolman
04-09-2017 09:00 AM
lostinfords
Large Truck
05-20-2016 08:42 PM
