Freestye 2005 electricial
On my wifes freestyle when you are driving it day or night lights on or lights off all the guages with needles will go to 0 or look like the car is turned off. The computer read out where the miles to go to empty/odometor will stay lit up working properly. it may stay off for 2 seconds or 10 seconds. At first I thought it went off while driving and you hit a bump but the other day i was sittin still in a pva and it did it. So does anybody have a clue as to what is going on? I attempted a search but could not find anything but I could have not been using the correct words to pull it up. Thanks for any help.
Nota
Nota
It's been awhile since I've seen one, but we were replacing a lot of clusters in Freestyles, 500's and Montegos for a similar problem if not this exact one. Tended to be intermittant. Search OASIS, there might be a TSB on it. Replacement requires a visit to the dealer, the module in the cluster has to be flashed when installed.
IDIDieselJohn
12-27-2010 05:15 PM
Futuresweets-10
11-13-2008 11:46 AM
