Bronco II Ford Bronco II
87 B2 water leak.
Old May 26, 2010 | 10:20 AM
fran40jomo's Avatar
fran40jomo
87 B2 water leak.
Hey we rebuilt our 87 2.9. Runs good but having problems with water in oil. we pulled it again, spent alot of time doing intake gaskets and added silicone to all suspected spots. Any ideas or fixes out there?
Old May 26, 2010 | 01:36 PM
mrshorty's Avatar
mrshorty
The 2.9 has a reputation for cracking heads. Have you pulled the heads off and had them inspected?
Old May 26, 2010 | 06:11 PM
rebocardo's Avatar
rebocardo
Check the pass. side head for cracks. There are topics on this. If you do a leak down test, you might see bubbles in the coolant, a compression test might narrow it down too.
Old May 30, 2010 | 09:23 PM
fran40jomo's Avatar
fran40jomo
We had heads done at machine shop but I dont think they magged em or anything. No oil in the water or mixing in oil to a white or yellow yet but it loses enough on a one hr drive to overheat. Hate to give up on on it after lots of labor and $.
Old May 31, 2010 | 11:53 PM
rebocardo's Avatar
rebocardo
It might be a freeze plug, doing the testing is the only way to find out for sure.
fwiw: I found one leak in a "blown" engine and it was the heater core that was leaking once I put a radiator pressure tester on it. I put about 30,000 miles on that $300 B2 before I blew the engine for real.
mtcable
May 16, 2011 10:36 AM
franks87
Bronco II
Feb 18, 2011 03:03 PM
jon87transam
Apr 1, 2008 09:24 PM
dmc919
May 12, 2004 06:48 PM
