Bog on initial hard acceleration
After I let the engine warm fully, If I get on the pedal as much as 3/4 to WOT it will bog...but only the first time and for a second or so. After that first instance, it will not do it anymore as accelerations are smooth, strong and consistant.
That is until the engine cools over night and I start all over the next day.
Thanks all.
Thanks all.
if you have the early build truck you could have a small exhuast leak starting around the expansion joint (usaully the left side) that when the engine is cooler it's leaking a little and then when warmed up it seals back off. the 03 and early 04 are real picky about that. If not that also could be turbo sticking
My 2005 has the bogg at initial hard acceleration ie merging into traffic when you need a quick response so far no easy fix besides tuning, FICM mod etc. just got use to it and don't expect it to take off like a gasser. I am told the 6.4 fixed the problem with dual turbos seems like an excessive fix just for this problem.
Thanks all.
Thanks all.
What kind of exhaust?
Do you use dino or synthetic oil?
DSMMH
Took today off to try a pay a little more close attention to my issue. This is only happening when the pedal is stomped somewhere between 1200-2500RPM (which is my typical driving range) and lasts only for that initial second of the stomping, not any longer. If I've ever launched from the line, I'll build boost first.
The term "Bog" does not really apply here so I apologize for the confusion.
Anywho, I believe it is just normal turbo lag. Sometimes that 1 second or so can seem like a lifetime when your trying to react to something like ummm... ::coughs:: ricers... ::coughs again::.
Take care.
Take care.
Take care.
Take care.
DSMMH
jay42782
46
08-01-2009 05:22 AM
Broncoslocos
06-23-2008 09:48 PM
mini_fly
05-07-2006 12:42 PM
