rebuilding my $150 78 bronco (they paid me to take it)
#108
I do have some news, there is a change of plans in the bronco project. There was a fellow at work who has a 79 f-150 with a 400, 4speed 4x4 that he is tired of looking at an wants to get rid of it . so I am going to be taking possession of this truck an will be parting it out ! I will be converting the bronco to a 4 speed truck . I love driving stick .
#111
#113
#114
Hello I know its been years since i posted anything here so let me give an update on my bronco. The parts truck i got for a manual trans swap was a bust .The trans turned out to be junk so i will just going to pull the c6 out an repair it .The other thing that has changed is i'm going EFI on my 351M it is a budget build cause $$$$ s always tight. for my EFI i scavenged the computer,wiring harness, MAP sensor,coil an the ignition module. I had the throttle body already .
making the harness
time to solder everything
harness done
fitting harness on motor
throttle body with adapter plate
MAP sensor an fuel pump relay mounted
coil an ignition module bracket
Okay coil and ignition module mounted .That's it for now and it wont be 4 more years till next post lol
making the harness
harness done
#115
#117
Well the yellow an white body you see was the original body of my bronco It was to rusty to fix plus the cost of rust free tub from work was only $100 an i pulled it on my weekend was a no brainier .
I also received a box from speedway today that contains a 20 circuit brand new wiring harness cost $180 with shipping will take some pics tomorrow .
I also ordered some relays from summit so i can redo the entire wiring in the bronco. well thats it for now
#118
#119
UPDATE:
It is with a heavy heart to announce this project will no longer be finished the reason is I got really sick I was diagnosed with cancer in 2016 and over the years it has spread I'm fighting it with everything I got. I'm doing pretty good but the bronco project is too much for me to handle right now
