05/23/2010 Ride of the Week
Ford Unimog
I will try to answer some of your questions.
1. You are right! The tires are mounted backwards, (i.e. right tires on the left side) We where just testing two almost identical trucks trying to find out if the traction in the snow would be bee different between the trucks. No result up to now. Also if they would create less noise on the pavement, the probably make more noise mounted backwards. I will move them back.
2. The volcanic eruption is over (at least for the time being) Here is a link to a web cam pointed at the mountain “Eyjafjallajokull” http://eldgos.mila.is/english/. I think its fog there now so you don’t see much.
3. The fenders are custom made here in ffice:smarttags" /><ST1lace w:st="on"><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com</st1:country-region>Iceland</ST1lace> by a friend of mine. Sry, we have not made mouldings jet but it can be done. But there are similar fenders available . You can see them here:
http://****************.com/gnl.html
You can almost get fenders fore all tiresizes build in Iceland</st1:country-region></ST1lace
<O
4. Yes the axels have original centre tire inflation system. This is the control panel for the tires and air suspension. The meters for the tires are very accurate, plus- minus 0.1 psi and cost about 200$ each (5) . Expensive!
<O
Hope you like it.
br. Thordur
<O></O>
<O
<O
Hope you like it.
br. Thordur
<O></O>
GreatNorthWoods
21
10-10-2012 09:46 AM
Brown Falcon
18
01-13-2012 05:38 PM
cdrmotorsports
1999 to 2016 Super Duty
22
09-03-2010 12:02 PM
