loud engine knocking sound is scaring me...
yesterday was the second time in the month I've had this truck ( '94 F-350 7.3IDI) that it has made a loud knocking sound when I started it up. (sounds just like an old 8 cyl wagon with a blown head gasket I once had-that was NOT MY FAULT :-)
The first time I had turned the key, it caught briefly,but when I released the key it stalled. So I immediately turned the key again, it caught, but there were 3 distinct BANGs before it smoothed out. That was about 10 days ago. I checked the oil, it is where it was when I did the oil change- halfway up the hatch markings on the stick. Oil gauge reads 3/4 when the truck has started up.
The second time was 2 days ago-Wednesday- this time there were about 7 bangs before it smoothed out. I had not started it since coming home from church Sunday- don't know if that makes a difference. Still no change in the dipstick. The oil change I did was a Fram filter, with Valvoline blue 15W40 oil for diesels (I can look at the jug if it matters) The oil I drained was ridiculous sludge- I was considering doing another change after 1000 miles,but it's only been about 700 so far.
any suggestions?
tia
lee
any suggestions?
tia
lee
on
Test your glow plugs.
Could be a sticky injector, pull the fuel filter, empty it (in a safe manor), fill it with your favorite Diesel Injector cleaner lubricator, triple the dose in the tanks, let it run for about 45-60 seconds, shut it off and let it set for as long as you can, couple hours at least. See if that helps.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
Valvoline Blue and a FRAM.... that's like socks with sandals..... use a good filter Wix, Fleetguard, NAPA etc.
bozone802
27
05-11-2020 07:44 PM
Mander
06-18-2016 07:28 AM
74 F350 SCS
08-25-2012 07:15 AM
andrewscofield
48
07-22-2012 12:41 PM
