I have a 2002 Ford F650 SuperCrewzer with the Cat 3126B and 6 speed auto, at 1800 RPM it travels at 60 MPH. I think these engines should not be run over 1800 RPM and when I do the MPG goes down. I would like to get more SPEED (don't we all) with out loosing MPG, would it be wise to change the rearend gears? or does someone know what would be a good solution.
Larger diameter rear tires will give you more speed without more RPM, but your speedo will be off. A GPS can show you the exact speed your traveling, and you can make a cheat-sheet and tape it to the dash
Other than that, rear gears are the only other thing that will bring up your speed. Or an overdrive unit.
I used to have a '98 Ranger that came with 225/75R14 tires and I switched to 235/75R15 tires. I found out that the speedometer was actually "driven" by the computer so I took it to the Ford dealer and he reprogrammed the computer for the larger tires. Easy enough.
