Link to BigLick
Link to BigLick
Truck & Tractor Pull_Big Lick Festival Park, Oakboro, NC
For those who haven't been, this is the truck pulling event that Scott and I talk about. Check it out.
Mine is easy , you just turn the screw on the IP, but I can't make enough boost to to need more fuel.
Its not fuel pressure that I am running out of, its volume. I can adjust my pressure anywhere I want too at idle but no matter how high I set it when Im on the fuel the system cant supply enough quantity. I need bigger pump and bigger lines from the tank to the engine. Thats not in the budget right now with twins on the way so it will have to wait.
