how do i know if my tuck has a keyless entry?
Old 05-18-2010, 11:11 AM
jimjoebob99's Avatar
jimjoebob99
jimjoebob99 is offline
I just had to deal with this and got a new key fob last week. Got it all programmed and it works great. The module is directly behind the little inset in the dash to the lower right of the steering column. You know, it looks like a place you might put keys or change right next to where your right knee would be. If you remove the lower trim panel there, it says that it's the keyless entry module or something to that effect (I don't believe that you can read it while the lower trim is in place). That is where it is in my truck and I have a 95. The plug that your looking for that has the wires you need to jump for programming is taped to the harness underneath the module and I believe that it is a gray plug.
The sequence for programming the remote is:
1. Turn the key to the on position.
2. Use a jumper to short the two wires in the connector under the dash (the grey two wire connector) and the locks will cycle from locked to unlocked, to let you know that it's in program mode.
3. Press any key on the key fob that you want to program. The locks will cycle from locked to unlocked again to confirm that the remote has been programmed.
4. Repeat step 3 for any additional remote that you want to program with it (I believe that the system can support up to 4 key fob's).
5. Remove the jumper wire and turn the ignition off. The locks will cycle to locked and then to unlocked to confirm that your exiting programming mode.
Note: If you add or remove key fob's from the truck, you have to program all of them again each time you program the module.
I'm not sure about getting one from the junk yard but i've heard it works and is plug and play as long as you have the correct harness in the truck. I also have the blinking theft light on the dash and believe that this is part of the system. I'll try to take some pictures today if anyone needs them in a little bit. I did quite a bit of research on this a while back and hope that this helps everyone out.
Here is a link to the key fob that I purchased. 1993 1994 1995 94 95 FORD EXPLORER KEYLESS KEY REMOTE: eBay Motors (item 230469850703 end time May-07-10 11:47:38 PDT) I believe that any one around this year from a Ford Truck will work as long as it has the same FCC ID and it's the 3 button layout (you don't need the 4 button because you don't have a trunk).
Old 05-18-2010, 11:38 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
The RKE harness is tied into the rest of the wiring for the truck, so if you didn't get factory RKE then it is NOT plug and play, at least not from what I've seen so far.
You are correct.
Old 05-18-2010, 02:58 PM
jjoel's Avatar
jjoel
jjoel is offline
I've looked in that area... I guess I don't have keyless entry Looks like i'll have to get an aftermarket one.
Old 05-18-2010, 03:07 PM
fishforlife2007's Avatar
fishforlife2007
fishforlife2007 is offline
i just looked in the area and i have the large box. it looks to be blue in color?? is this rite?
Old 05-18-2010, 04:39 PM
superduty4x4
It should be black but might be blueish looking from under the dash. Probably 4" x 4" x 6" or so with 3 connectors on the bottom, and a small 2 wire connector taped to the harness somewhere near it.
Old 05-18-2010, 09:39 PM
fishforlife2007
mine is about that size... if i remember correctly the connectors were on the side. bigjoe posted a pic of a box, and i do have that box behind this larger box that i am talking about. there is also a foam flap that is covering it.
Old 05-19-2010, 07:31 AM
jjoel's Avatar
jjoel
jjoel is offline
hmmm... i might have a box w/ a foam flap
Old 05-19-2010, 08:54 AM
superduty4x4
Connectors should come straight out the bottom but it sounds like you do have RKE.
Old 05-19-2010, 09:31 AM
jimjoebob99
This is a view of it from the bottom on my truck. The blue box is directly behind the RKE module. The plugs insert into the bottom of the unit and the view is with the camera pointing straight up. I didn't take any measurements of the physical but probably can in a bit. Hope this helps a bit.Name:  RKEmodule.jpg
Old 05-19-2010, 02:58 PM
fishforlife2007
ok...with that picture, i am unsure now...like i said mine is a box that is about robbins egg blue in color. when i took a second look at it i noticed that it has 2 connectors that i can see, and they are comming out the side of the box in question. there is another black box behind it closer to the firewall, which has one connector going into it.
Old 05-19-2010, 03:28 PM
jimjoebob99
I have the same blue box behind this one. The other one your talking about with one connector might be the door chime module which is removed in my truck. The RKE module should be between the blue module and your dash board (toward the seat).
Old 05-19-2010, 05:03 PM
superduty4x4
The blue one is probably your anti-theft module.
  #28
Old 05-22-2010, 11:39 PM
jjoel's Avatar
jjoel
jjoel is offline
1996 Eddie bauer and no keyless entry for me... This really stinks now I have to find a way to fix my door locks or add keyless entry
  #29
Old 05-23-2010, 07:25 AM
Filmy's Avatar
Filmy
Filmy is offline
I just bought an aftermarket remote keyless entry on the 'bay, thinking it would be an easy plug-n-play. But I recently found out that Ford uses reverse polarity power locks so I'll have to get and wire in a couple of relays. Makes things a little more complicated but not impossible. Just keep this in mind if you go the aftermarket route. Mine's a '93.
  #30
Old 05-24-2010, 09:17 AM
superduty4x4
93-95 Taurus uses the same module, I snagged the module and about 6.5' of the harness for $10 at the junkyard. About 30 wires to splice though!
Quick Reply: how do i know if my tuck has a keyless entry?
