need some help with AE / adjust for tire size
on
After the pcm logs on you will get the vehicle selection box. When it opens go to the bottom where it says System.
It should already say enhanced power train Click the drop down arrow and change it to anti lock brake then click on ok.
After the truck connects click on the test on board system tab. Click the drop down tab next to the initiate button and select
tire size.
When that opens there will be a left and right arrow on the far right next to the initiate button. Click the right arrow
to get a bigger tire.
tire size.
I have an illustrated PDF file on my web page that you're welcome to copy. Shows the screen shots for stepping through AE.
Maintenance
Maintenance
Pete thanks for the link, I appreciate it. reps sent
SAM ROYE
08-26-2014 01:59 AM
79FordBlake
04-17-2010 12:13 AM
