How to remove door panels...so that they can go on again!
I have a '75 F250 crew cab that needs some in-the door work...how do I remove the door panels (and any diff between front and rear doors) without tweaking any press-fit type fasteners so that they can be reused? is there any special tool needed? Thanks in advance! Brian
Mine had the wire/foam type fasteners and they didn't go back on very tight after I had them off. I haven't done it yet, but someone had mentioned that you can replace the wire fasteners with the newer style all plastic fasteners (available in the "Help!" section at auto parts stores). I'm not sure exactly what size is needed though for replacements. Maybe someone else here knows.
