1993 diesel mileage
1993 diesel mileage
Hi,
Im new here and Im looking for a ford diesel. I have found a local truck that is a 93' f350, crew cab, 4x4, with a diesel. The truck has a 5 speed trans. The truck has a stock turbo on the 7.3l and 260k miles and also a 4in. flowmaster exhaust system. The current owner says that its runs strong and smooth.
My question is how many miles do these motors and truck platforms go? Is 260k miles to many or will it last to 350k like most diesels?
Thanks
Thanks
on
Ask him what SCA's are ... If he doesn't know, RUN!
That's really the only thing to be leery of, if the coolant system has not been properly maintained it causes expensive issues.
If you can, get to it before it's started for the first time of the day, seeing it started for the first time of the day can speak volumes, does it start quick and easy, does it run smoothly as soon as it starts, whats the smoke look like if any, does it knock or anything like that.
Typically every 100k or so it's a good idea to replace the Injection Pump and Injectors, currently ~$600, Thats not saying they will go bad then, they've lasted several times that, they just degrade slowly over time and it's hard to feel it until you get new ones and the fuel mileage increases and it's got more go...
Glow Plugs ... ~$10 each, Infrequently.
Injector Return Lines like to leak if you touch them, maybe not fuel but air thus causing hard starts.
But like has been said, they have been known to last 500k+.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
on
SCA = Supplemental Coolant Additive
Some reading on Cavitation, The reasons for SCA's, it'll explain a lot: Cavitation Article
-Enjoy
fh : )_~
-Enjoy
fh : )_~
-Enjoy
fh : )_~
-Enjoy
fh : )_~
After reading the link - I went and checked the coolant in my truck - looked clean and green..... Luckily, my mom always had the truck well maintained.... but I am going out to buy some test strips tomorrow...
Thanks again..
My 377k mile 7.3 is still running as great as it did off the assembly line. The body is rotted to hell, witch is why the truck is parked at the moment, awaiting a body swap.
Only thing I plan on doing to the engine is cleaning it up and changing all the seals and gaskets, oil is leaking from every one of the seals. lol
Simple regular maintenance and coolant additives will go far in a 7.3!
I am the original owner of the truck though. Bought brand new in 1990.
