Cold start 2006 F250 6.0 diesel
It shouldn't increase much if any, 48 volts is spot on. The FICM volts need to be greater than 45 at all times from KOEO, cranking, idle and WOT.
Thanks I am having problems when the truck sits all night the next morning it misses and rattles but when it warms up it runs like a champ I just change the oil and filters and added RevX got about 100 miles on it hope that it works
I tested the Ficm this morning ad the voltage wa about 49 Koeo and also with it running
If you pass that, i'd say your suffering from some injector stiction, could take a bit more than 100 miles to work itself into your injectors and clean em up
