2007 Front Cowling Left Side Loose
It appears a screw is loose or something but the left side is popping up and if you pop it back in it stays. The three plastic clips that connect the two sides look fine but after a few bumps on the road it comes loose. The only thing that looks like it may be holding it down is a plastic fastener from the top towards the driver side windshild. The dealer says $250 to replace. Left side and right side slide a little bit but the right side (passenger side) feels more secure. I removed the rubber seal but don't see any screws. Any ideas other than replace?
I used a 1/4" diameter plastic rivet like retainer with a broad head, drilled the 1/4" hole so the head overlapped the higher side, pop it in place, not noticeable and it works.
Get them at Lowe's in hardware or auto store I rekon, like what holds the plastic under my Forester.
tbear
10-13-2008 06:39 PM
Kyle
08-16-1999 10:41 AM
