Rockwell Build Thread
#601
#602
#603
#604
Haha. You can't move this thing with a battery sitting on it. Once again though, we've built something that ya'll would have built differently. We'll just have to see how out works.
I have decided on new tires though. I want a set of 44" boggers and a set of 46" ags. After I get the front bumper built, I'm gonna start on a set of rockwell 15's unless I can find a used set for cheap.
#606
#607
Isnt half (if not 90%+) the point of building a removable hitch mounted winch is REMOVING IT? This ******* is going to weigh 250-300lbs if not more. Its not the issue of 2 guys picking up that much weight roughly waist high...its maneuvering that little 2" square tube into a 2" square socket while holding 300lbs waist high.
Im diggin' the tire choices also
#608
#610
Id buy 2 and keep my schnuts in their socket where they belong. I probably couldnt move the winch alone if it were sitting on the ground...much less the mount and battery as a unit.
Or Id build a bed mounted jib crane with a boom long enough to reach the front and rear bumper as well as my buddys truck if he parked close enough.
#611
#612
ags don't flex so well on the rocks DAN. I already went the cheap route and we all know how that went.
#614
