1989 Ignition Cylinder
Old 05-08-2010, 11:15 PM
GloveGuy's Avatar
GloveGuy
GloveGuy is offline
Hi there,
I've got a 1989 F-Super Duty, manual transmission with a 7.3 diesel. Recently, the ignition has gotten sloppy where the top of the key sits in the cylinder, so much so that it, now, has to be in just the right spot to rotate. Anyway, I've got a new ignition cylinder to replace the old one, but I can't get the old one out!
My Hayne's guide says I need to have the old cylinder in the "lock" position to depress the retainer pin and release the old cylinder. I found a source online that says the old cylinder has to be in the "run" position to get the old cylinder out. Neither has worked, and now I can't even rotate the the old cylinder to get it in the "run" position to try it again!
I noticed, on the new cylinder, the retaining pin won't depress in any of the key positions. Am I missing something besides my sanity?! lol!
Any suggestions are very welcome and appreciated. I'm hoping to get this truck back on the road by Monday morning. I'll just keep the steering wheel off and see if anyone has any suggestions.
Thanks, in advance, for your time. I look forward to your reply.
Regards,
gloveguy
Old 05-09-2010, 06:48 AM
gearloose1's Avatar
gearloose1
gearloose1 is offline
The retaining pin on the new cylinder have 2 possible positions. That is the silver thing on the spring clip.
Remove it, reverse it, and it will work.
I think mine too, came that way from the box with the pin in the opposite way.
The smaller one is "out" not the larger one for me 2005.
Old 05-09-2010, 09:18 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,680 Likes on 1,357 Posts
If you can't get the retainer to release, you can break the chrome part off and get it out. This happens all the time, and I know it sounds a little crude, but take a chisel or large screwdriver and get behind the chrome piece and hit it with a hammer and it will break off. You usually then can get to the retainer and release the old cylinder.
Old 05-09-2010, 12:11 PM
GloveGuy's Avatar
GloveGuy
GloveGuy is offline
Well, i've managed to get the old cylinder out, now when i put the new cylinder in, it only goes in so far, then seems to get hung up. i've got the new cylinder in the "run" position and the pin on the new cylinder is pushed in. i'm still working on it, but any suggetions would be great.
Thanks for the help, so far!
Old 05-09-2010, 01:54 PM
GloveGuy's Avatar
GloveGuy
GloveGuy is offline
Whew!
Well, after verifying several times that i, in fact, had the new cylinder aligned properly, i just put a little extra grease on the cylinder and gave it a few encouraging taps with a light rubber mallet and, presto!, it's in and seems to be working in all key positions.
Thanks for the quick and helpful replies!
Regards,
gloveguy
6t6merc
10-14-2013 02:25 PM
GloveGuy
1999 to 2016 Super Duty
02-19-2009 11:34 AM
bwilliams7527
02-18-2007 03:52 PM
93Mule
1978 - 1996 Big Bronco
07-23-2006 11:24 AM
hhanse57
1983 - 2012 Ranger & B-Series
04-01-2004 05:47 AM
Quick Reply: 1989 Ignition Cylinder
