New blue CPS?
FWIW my OBS had a gray CPS when I bought it. I came up with a #2 and #4 high to low side open code. Swapped to a used black CPS I had (have one more plus a brand new IH black CPS still...) and the codes went away. The gray CPS is evil, throw it away and get something else. On that note, if someone has a failed black CPS or one they don't want please send it to me... I want to do a comparison between black and gray underneath the plastic.
It's a sticky right at the top of this forum. LINK
But just the same I did not know this about the OBS PCMs. I did know that our e99s PCMs could not run a rotational velocity test.
So far so good with the new truck. Installed new glow plugs on Friday, need to get it cleaned up more inside yet. I don't know what this "garage" you speak of is We don't have any enclosed parking at our place. I'd probably need 30' to get it inside and be able to shut the door I'm guessing.
on
you can get this CPS at IH they have had them for a couple of month now.. just reading a few threads that the new cps is not failing anything and truck runs good..i also read the IH and the Ford CPS are one in the same sensor...
Dark blueish/purple,International #1876736C91
<!-- / message --><!-- sig -->
my early 99 runs the RV test.
#30
just installed the dark blue/black cps. ordered from mike at tousey ford...22 bucks shipped. anyway, didnt get a chance to fully drive it but it started up easier than it has ever done. i had mine changed when i bought it at the dealer under recall, not knowing about all the problems. i was getting 17 plus mpgs with the original, and am down to mid 15's with the grey one. ill post back any insight about the dark blue one. didnt have any problems to say, but have nothing to compare it to.
chris
chris
