Front axle bearings and seals
I'm doing my first axle job on a '75 Hiboy w/ Dana 44. Learning as I go, following Haynes as best I can.
I'm trying to extract the driver's side axle shaft. I've gotten through the hub (not OEM) and wheel bearing locknut.
So now I get to the part where it says "remove the retainer and related components". On a Jeep site, the consensus was that the retaining ring needs to be drilled/chiseled out to release the adjusting nut.
But the pictures in Haynes look like I should use a tool through the holes to extract. What do I do?
After the hub theres the inner part of the hub (what the teeth of the hub go into) that slides out, then the first axle nut. Then a circular piece with a bunch of holes in it, it just slides off the key way, then theres a second axle nut that looks exactly like the first, then your to the wheel bearing and the rotor will pop off. The axle nuts either use a special socket or you can hit them with a flathead screwdriver and hammer to loosen them up. This might sound complicated but just dig in and remember the order they came off in. (I wish i would have taken pics, i just had mine apart today.
So the stage I'm at, there's a single tooth "washer" with a bunch of holes in it.
The first lock nut came off without any coercion. The tooth on the "washer" sits in a gap in what I think is the second "bearing adjusting nut". (Near as I can tell, it's threaded onto the hub and holds the bearing.) I can get a degree or two of rotation in either direction until the tooth hits the notch.
My issue is that I can't tell from Haynes whether this is a "destroy now, replace later" part that needs to be pressed back on or if there's something more elegant I should be doing to get the "washer" out of the way to get at the second nut.
john jamieson
07-04-2016 07:13 PM
ultraranger
18
02-22-2016 03:27 PM
