motor swap out
motor swap out
So I have a 2001 F150 sport 4x4 manual 4.6 extended cab truck that I destroyed the motor in (the machinist of 30 years was VERY impressed with the damage that had been done, said I had done a nice job) anyway I found a 1997 crown vic 4.6 police interceptor automatic and am wondering if the change over will work. I called the local Ford dealer ship and they said it would work but would need to find a PCM (Power Control Module) form an automatic crown vic so the truck knows that the new motor is from an auto and not a manual. Does this sound right? Am I heading down the right path with getting a new PCM. Also is there advantage with having the police interceptor motor and what pieces wound I have to keep from the interceptor i.e. intake manifold. Look forward from hearing from the wise. LOA <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
So I have a 2001 F150 sport 4x4 manual 4.6 extended cab truck that I destroyed the motor in (the machinist of 30 years was VERY impressed with the damage that had been done, said I had done a nice job) anyway I found a 1997 crown vic 4.6 police interceptor automatic and am wondering if the change over will work. I called the local Ford dealer ship and they said it would work but would need to find a PCM (Power Control Module) form an automatic crown vic so the truck knows that the new motor is from an auto and not a manual. Does this sound right? Am I heading down the right path with getting a new PCM. Also is there advantage with having the police interceptor motor and what pieces wound I have to keep from the interceptor i.e. intake manifold. Look forward from hearing from the wise. LOA fficeffice" /><o>></o>>
JL
The intake manifold from your truck will not fit properly on the '97 engine.
You'll give up approx 20hp due to the lower power output from the CV engine.
There are many other little annoyances that will make this swap a PITA.
JL
JL
Philthy50
32
12-27-2015 09:41 AM
fun4evrusa
08-12-2015 08:08 AM
DeadPhish
25
06-18-2015 08:52 AM
carcrafter22
32
10-21-2013 06:49 PM
