f150 vs f350
f150 vs f350
whats the difference between the f150 and f350s beside suspension? im looking to do a SAS with a cummins swap but im having a hard time finding a single cab, long bed 4x4 f350 around here for cheap. so could i SAS a 150 and put a cummins in it and not have to worry about bending anything on the frame?
well I know my 88 F250's are thicker than the 92 F150 I had so there is probably thicker steel on the newer 92+ F-250's... What are you looking to do exactly? swap motors? do some towing/hauling? What's the goal of the project? Upgrade the truck you have???? More details needed!!!!
F-250's and F-350's have thicker frames, heavier suspension, taller ride height, heavier trannys... I mean where do you begin... I wouldn't buy another 150 after having my F-250's...
oh ... ok... yes use the thicker F250 or F350 frame. 87-91 frames can be found in plentiful supply if you need on and are should hold up just the same as a 92+ F250/F350 frame. You'll have little to no modification needed. Everything won't be bolt on but you can find them cheap enough. Shoot I saw 3-4 F250/F350's for parts or whole on craigslist today for under $350...
Ahh, you are doing exactly what i want to do. The F150 frame will hold up fine. The F350 frame isnt any taller then an F150 frame, its just a little thicker. So no problems with the F150 frame especially if its a single cab long bed. Shorter frame means stronger frame.
The only issue you might encounter is if you are making tons of torque. Over 700 ft-lbs which might cause the fram to start twisting. The C-Channal frame doesn't like twisting. But that can be solved with a well placed cross member.
i guess i should go with a 250 frame
Ya, with that much torque, even an f350 frame is gonna have a hard time. i would get a good frame and box it and reinforce it. Even the one from your F150 would be fine if you boxed it and reinforced it. Thats the only way you'll get a C-Channal frame to handle that much torque. Otherwise your gonna be breaking welds and cracking the frame all over. And to handle that power, your gonna have to do alot to the rear suspension anyways, 4 link, or traction bars. So you might as well start beefing it up.
That makes sense. I was wondering why you were in the pre 97 forum.
If your gonna buy the truck i would start with an f350. That way you are already starting with a strong platform. Although with that much torque you'll probably have to reinforce the F350 frame as well depending on exactly what you do with it. towing, racing, off roading.
Im thinking about a 6bt in my 93'. My only concern is the weight if im gonna be off roading. i dont want a truck that nose dives all the time. I dont have any concerns for the frame though, but ill be only be shooting for 600ft/lbs or soo.
Justynantone
02-09-2017 06:54 PM
Sparky96
03-20-2015 08:04 AM
surewhynot
01-20-2006 06:58 PM
1990, 1996, 250, 350, difference, differences, f150, f350, ford, frame, race, reliability, torque, trader19871992, truck
