Stock oil gauge v. stock idiot light v. mechanical gauge
Old 05-06-2010, 07:13 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,078 Likes on 2,148 Posts
actualy it started in 87 with the new body style, not 88
Old 05-06-2010, 07:54 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
My '87 has a variable resistance oil pressure sender, as did an '88 truck I snagged a wiring harness from. I always thought '89 was the first year for the "dummy gauges" since there were some changes in the wiring that year as well.
Old 05-06-2010, 11:46 PM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
Originally Posted by nstueve
The only problem with that wiring set up is that you'd have to wait for the engine to become hot enough to trip the engine light... And by that time you might already have engine troubles... I thought the point of the OP guage was to give and immediate warning light to the driver of low OP...???
No you don't - the sensors for the coolant temperature and oil pressure are wired in parallel, so they can each ground the circuit and trigger the light on the dash independently of the other sensor. Basically when the light comes on you'll have to look at both the coolant temp and oil pressure gauges to see which one is pegged, but the purpose of grabbing the driver's attention is met.
Old 05-06-2010, 11:48 PM
jonathan.e.green's Avatar
jonathan.e.green
jonathan.e.green is offline
So the oil temp gauge is really an 'idiot gauge?' Why bother then? The water temp, voltage and fuel gauges really work.
Old 05-07-2010, 03:52 AM
LCAM-01XA's Avatar
LCAM-01XA
There's no oil temperature gauge, you have coolant temperature which works like it should, and oil pressure gauge which is an idiot gauge.
Old 05-07-2010, 12:00 PM
jonathan.e.green
Er, right, oil pressure. Typo.
93F250HD's Avatar
93F250HD
93F250HD is offline
Depending on what options you have you may have just an idiot light. My truck like many have an oil pressure gauge that is variable. I know this because when I replaced the sender the guy at Advanced Auto gave me the idiot light sender when I needed the actual variable one, so I had to make the trip back down to return it and go to NAPA, pain in the butt. I do also believe that if you have the variable one like most do, and it drops low the check engine light will come on.
Old 05-08-2010, 06:34 PM
phoneman91's Avatar
phoneman91
phoneman91 is offline
I wish!!!
I don't think that most 93 vintage F series have a factory variable oil pressure sender. I suspect that you truck got converted in the past by a PO.
Old 05-08-2010, 08:54 PM
93F250HD's Avatar
93F250HD
93F250HD is offline
If its a gauge that looks like the temperature gauge its variable, if its square and says oil pressure on it and lights up in RED its not. Not conversion, Factory when you go to a NAPA and the guy reads his computer he will ask you if it has a variable pressure gauge, if you put the idiot light oil pressure switch in, the variable guage will stay at 0
Old 05-08-2010, 10:33 PM
phoneman91's Avatar
phoneman91
Not true. The factory "gauge" uses an off or on sensor . It will read in the middle of the gauge if the oil pressure is 6PSI or more. If less than 6PSI---it will read no oil pressure. There is a resistor factory wired to the back of the gauge to make sure that it always reads in the middle and that the needle doesnt change when the temperature of the oil changes and when the RPM changes. The needle on a factory setup for your vintage will never have the needle move at all-if the oil pressure is 6 PSI or more.
Take a look at your factory oil pressure gauge. Does the needle ever move when the engine is running?? If so-it has been modified. I have been told that if a variable sender from an earlier F series is added-and the factory resistor isnt removed-the gauge will become variable-but only for the first half of the gauge range---not the full range of the gauge. Because the resistor limits the full range of the needle.
I checked www.napaonline.com and noted that NAPA calls it a switch-not a sender. For our vintage F series.
This oil pressure "gauge" for this vintage F series is one of the most sucky things that Ford has done .Why would Ford cheap out on something as important as an oil pressure gauge?
My Jeeps have real electronic oil pressure guages from the factory and you can see the needle move as the oil warms up and when the RPM changes. And the Jeep gauge is graduated in PSI.
Old 05-09-2010, 01:24 AM
LCAM-01XA's Avatar
LCAM-01XA
It's my understanding that it was not due to costs, but due to a high number of dealership visits with complains of the gauge reading on the low side (mostly with the 302 and 351 engines) - so instead of fixing the low pressure issue (which isn't much of an issue to begin with) by modifying the pumps, Ford took the easy way out and just covered it up with that switch and resistor bull. Yes, very sneaky and totally unprofessional, but that's the big corporate world for ya
brain75
31
02-05-2016 06:01 PM
Jonnys.1991
08-11-2015 01:56 PM
Shadowrider123
06-03-2015 09:38 AM
goodbread
1983 - 2012 Ranger & B-Series
51
01-13-2015 10:17 PM
jimthibodeau
12-28-2014 12:18 PM
Quick Reply: Stock oil gauge v. stock idiot light v. mechanical gauge
