REAR GEARING F450
REAR GEARING F450
I know there are a pretty sharp bunch of guys on this site. Sure you guys can give me good answer. A buddy of mine has a 99 F450 7.3 rollback with 4:88 gears. At 65 to 70 mph she is clocking around 2700 rpm. She burns some serious fuel at that rpm. Sometimes we get into running up a short grade here in the mtns. What would we lose if we say went with a 3:73 ratio? BTW it is a manual 6 speed trans. Thanks
Smokie
Smokie
F250 Wheels ! How did the truck run down the road with a load ? Did you have enough power to climb the hills? What kind of rpm were you running at say 70 mph? Did your mileage inprove any? This truck was I think mostly for town use and has a small 16 gal. tank. We use it to haul cars from auctions and they are all about 1 1/2 hours or more away. It seems we are always at the pump!! It is either better mileage or a bigger tank!!! Thanks
Smokie
Smokie
F250 Wheels! Thanks for the input. One guy told my buddy that a gear change would just kill the truck!! The only thing I think will hurt is maybe aceleration. It is only a 7.3 but to me my 7.3 with 3.73 gears can haul my fiver with no trouble! Granted it has to work some but that is why you buy a dezzel in the first place. They are workahaulics !!!
Smokie
Smokie
I don't think I'd want to go down to 3.73's from 4.88's. I would hit the 4.33's and try those first.
Also remember, if this is a 4x4, you will have to swap BOTH SETS of gears, not just the rears.
If you want to get accurate rpm at ??mph calculations you will need to know the tire diameter. The wheel diameter doesn't mean anything as far as calculations are concerned. IMO 4.30s would probably be a better bet. Keep in mind the 6.4l in the newer trucks is a whole different beast than the old 7.3l. If the truck has never had the gears changed there should be a tag on the axle diff cover that tells you the gear ratio, thats if its still readable. I never heard of Ford putting 4.59s in anything, for the chassis cabs 4.88s were the norm.
I am going to put the vin number in here maybe you fellas may have a better site to check than I did! Maybe you can get something from it? Thanks
vin 1FDXF46FXXEA61011
Smokie
Smokie
