Lock Actuator Fix WITH Pictures!
#77
^^^ hes rite. priceless. if i had done this sooner i wouldnt have been taking my back window out when my daughter locked my keys in my truck. this was alot easier than i thought it would be.
i cut up 2 pennies for mine. this was the cheapest repair i have ever done
#78
I got the actuator out, did the fix but can't figure out the installation again. I already broke one actuator. So detailed explanation would be greatly appreciated! Also does the actuator have to be fully installed to work, or should it work once the plug is reconnected? Thanks for the help!
#80
Great write-up and pics Jon. I did this back in November when I was just a troll on FTE. Glad to see someone brought it back so I could see who to rep for it! I probably should have read the whole post at that time and I wouldn't have taken all 4 lock assemblies out when I did it! On that note, reps to you Rubberduck!
#81
Actually, I got my info from here and then just expanded it and turned it into a writeup that I thought would show people all they needed to know... basically, I just did my best to keep folks from guessing. I also got some info from here so, the credits go to them, really... glad it worked for y'all!
#82
I understand what you're saying but still gotta give you credit. Write-up, pics, made the job super easy. Just wasn't a member then and didn't even think about it till I saw it on here again and realized it was the one I had used to fix mine. I appreciate all the folks on here, but you get the cookie for this one!
#83
#84
Glad I could could help.
#85
Good write-up Jon, the pics always help a how to. This is my cherry buster mod. This is the first mod I ever did to my truck with info off FTE, don't even know what thread I was looking at. Think my second FTE mod, performed the same day as the first, was the door chime delete. I don't like my vehicles yelling at me.
Hey RubberDuck, think I saw you on 2222 today. White OBS dually, some stickers, Death Row Diesel cut out of chrome on the mud flaps, little belch of smoke every time you touched the pedal?
#86
#90
I think it was plain ol' steel... I actually made them outta those plates that you nail to your framing over the spots in the framing where the plumbing ruins through to keep your drywall nails/screws from punching holes through the plumbing. Works REALLY good! If I could do it again, though, I'd do what I did with a buddy's actuator. There are two contacts in there that spread apart when you put the "dummy load" in there... you can pull those contacts out and bend them in so that when you put them back into the motor, it shorts out and you don't need the dummy load after all.
