Hard to turn when the brake is appled
****** http-equiv="Content-Type" content="text/html; charset=utf-8">****** name="ProgId" content="Word.Document">****** name="Generator" content="Microsoft Word 10">****** name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CUsers%5CJSA-5%5CAppData%5CLocal%5CTemp%5Cmsohtml1%5C02%5Cclip_ filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> I have a 1999 ford super duty pickup the truck has a hydroboost power brake system and when I step on the brake pedal when the truck is stopped. The power steering is very hard I release the pedal the steering is fine.
****** http-equiv="Content-Type" content="text/html; charset=utf-8">****** name="ProgId" content="Word.Document">****** name="Generator" content="Microsoft Word 10">****** name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CUsers%5CJSA-5%5CAppData%5CLocal%5CTemp%5Cmsohtml1%5C03%5Cclip_ filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]-->I just replaced the power steering pump, it didn't fix the problem.
<o></o>
<o></o>
Hi kc0ti1002 and welcome to FTE.
OK, as you probably already know, hydroboost brakes are powered by the power steering pump. You have replaced power steering pump but still have the problem of hard steering during braking.
Aside from the new pump also being bad, you also need to check the power steering fluid level and the serpentine belt. You could also have a problem with the hydroboost unit and possibly the master cylinder.
Your truck should not do that. You don't have a hydroboost system, so braking and steering are not on the same system. Brakes on gas engines run on vacuum.
Indeed, however I was told that it was because the front wheels rotate a little when you turn the wheel. When you apply the brakes it doesn't let the wheels rotate. I wanted to test this by putting the front of the truck in the air and trying it, but i never found the time.
