2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Keyfob
Old 05-12-2011, 03:02 PM
real_texan's Avatar
real_texan
real_texan is offline
Keyfob
My key fob quit working so I replaced the battery and it still doesn't work. Do they have to be reprogram, and if so does anyone have the instructions.
Old 05-12-2011, 06:21 PM
rgilbert's Avatar
rgilbert
rgilbert is offline
Which vehicle are you asking about?
Old 05-12-2011, 08:57 PM
real_texan's Avatar
real_texan
2007 exp Eddie Bauer
Old 05-12-2011, 10:18 PM
rgilbert's Avatar
rgilbert
rgilbert is offline
See page 112 in the attached link and see if it will help. Replacing the battery should NOT lose fob programming, but you might be able to fix it by following these instructions from the user manual. Also make sure the battery is not in backwards. Don't ask me how I know.
http://www.fordf150.net/2007/2007-fo...ers-manual.pdf
Old 05-15-2011, 02:10 PM
shorebird's Avatar
shorebird
shorebird is offline
The programming is in the vehicle module.
the fob simply sends a coded signal to the vehicle.
The vehicle compares the code to it's recognized list.
From the owners manual;
Note: Replacement of the battery will not cause the remote transmitter
to become deprogrammed from your vehicle. The remote transmitter
should operate normally after battery replacement.
Programming remote transmitters
It is necessary to have all (maximum of six — original and/or new) of
your remote transmitters available prior to beginning this procedure. If
all remote entry transmitters are not present during the programming
procedure, the transmitters that are not present during programming will
no longer operate the vehicle. Note: Do not press the brake pedal
anytime during this sequencing, as doing so will invalidate the procedure.
Old 05-16-2011, 12:55 PM
real_texan's Avatar
real_texan
Well it just started to work all of a sudden. It took like 3 days after I replaced the battery to work for some reason. Oh well. It's all good now
Old 05-19-2011, 09:10 AM
reelsport's Avatar
reelsport
reelsport is offline
Key fob
I have a fob from a 03 Expedition could I reprogram and use it on my 07 Expedition?
Old 05-19-2011, 03:33 PM
shorebird's Avatar
shorebird
As I understand things you can.
When I have a vehicle going to salvage I collect the fob for reuse.
Mitch Bellinger
1983 - 2012 Ranger & B-Series
01-02-2017 10:27 AM
RileyCarroll
07-21-2016 04:54 PM
northey
07-22-2002 09:49 AM
Quick Reply: Keyfob
