What is needed for 500 HP powerstroke?
Hey guys, just was thinking at work today.. well everyday about power strokes. What would it take to build a daily drive-able truck with around 500 hp? I would assume trans/torque convert upgrade, bigger turbo (housing), stage 2 injectors, high pressure oil pump, high pressure fuel pump, custom tune.. Would the engine handle 500 hp? Is this obtainable or reasonable for daily driving? What would the torque be?
Just thought it'd be interesting to see what everyone thinks! We can all dream (well getting paid for it like i do at work hahaha)
Cash, cash, and more cash! Deven has some good ideas to start with. The nice thing about hybrids is you can tune them down to basically stock and drive around without issues (gotta love electronic engine controls). Joe (Izzy351) dynoed at 449hp and 1016tq. Check out his "about me" page on his profile to see what all he's running Ford Truck Enthusiasts Forums - View Profile: Izzy351
on
nice list right there..you can get away with medium oil...i just picked up a set of rod's..sending them to WOP as well as the bearings and a set of Mahle pistons to be cryoed, magnaflux, polish, and install new pin bearings in the rods my sump and fuel lab will be be here wednesday..deciding on 238'3 or 250's...ill be north of the 500HP mark after beans does the tuning...im still debating on sending my cam to dave lott to have it played with....
on
id like to but 2500 bucks is alot of cash...if i could find a used one i will be doing it..but there is a bunch of guy's pushing 600 on a stock bottom...tuning now adays are lot better then they was about 2 years ago...i dont want to race or beat my truck all the time..just want to know if i want it..its there to use..
on
The main stud girdle kits ties the main caps together to eliminate main cap walk and reduce the chance of block fractures and cracking at higher performance levels. there are a bunch of 500 HP trucks out there not using this and there still running strong..if i was going to 600..i would use it..there are trucks out there at 600 without it and they are still running strong.. doesnt mean its going to work for ever..kind of like going over the 400 mark on PMR's..some get lucky..some dont..
on
its too bad Joe has PMR's..he should have done better then he did..but no tuner is going to tune a PMR motor like a forged rod motor...got to love them injectors from fullforce though...mine did 436HP on a 97 with a 17 pump a D66 and beans fueling....i know im about the same as that..will be a lot better after i finish the fueling..these injectors will have a hard time to empty out because there will be plenty of fuel to reload...
As for the trans, yes you'll definitely need a strong build.
