2WD ZF5 S5-42 Small Block
Category: Drivetrain
Price: $450
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000, CL, TL & Vigor
Item Condition: TX
Engine: Part suitable for gas truck
Originally i bought it and was planning on converting it to 4x4. But i stumbled across a 4x4 ZF only hours before tearing it apart and decided to use the 4x4. I feel like the ZF5 is heavy duty enough that there is no way that there would be issues with it coming from behind a 5.8L.
It is a S5-42 with a 5.72 1st gear and a .75 Overdrive.
It has a fixed rear yoke.
im asking $450 and im willing to deliver partway depending on distance
There is no warranty and the transmission is "AS IS"
Thanks for looking.
If this is a small Block ZF5 then I should be able to change the bell housing with mine from a 300 I-6, If this is the case, is this transmission still for sale? And are you willing to assist in the crating process? Are you willing to drive to a shipper or truck transit yard to complete the sell?
I will continue my research while awaiting a reply from you! I hope this is the case, if so then a simple bell housing swap and a I should be good to go !!!
Thanks you, John
Thanks you, John
sorry for such a delay in reply's. Im currently off at school and free time is at a minimum.
Anyways, i do still have the trans if anyone is interested. I will help in crating and shipping, but i all the expenses(expect packing supplies ei: crate, strapping ect) will have to be cover by the buyer. The only know issue of the trans is that it is missing one bolt that holds the PTO cover on. This is a special bolt that is machined specifically for this type of trans. You can get one from any big block or small block zf-5, however, at 1st chance i will get one from a trans shop supplier i know.
This transmission has a integral bell housing, meaning that it will only work with small block ford engines. You cannot swap the bell housing on this transmission.
Also, i will not be able to ship this trans immediately. I can get it ready at thanks giving any hopefully get it shipped soon after. And i will do my best to get it shipped quickly. Please understand my situation.
Thank you,
Thank you,
I replied to the email you sent but i'm not sure you got it. I'm interested in the transmission, i'm available to come get it on wed and thursdays only because I work out of town and im in San Antonio those two days so it wouldn't be hard to come get it on those two days.
Call or text me
2103253264
Call or text me
2103253264
