Stealership Results!!!!
Old 04-28-2010, 07:11 AM
caverjoe's Avatar
caverjoe
caverjoe is offline
caverjoe has a very good reputation on FTE.caverjoe has a very good reputation on FTE.caverjoe has a very good reputation on FTE.
Got the guy on the phone finally. He starts off with I might just want to think about getting a new truck cause its ugly.
Anyway he says I have 4 injectors out and maybe something in the bottom end, but he would have to do a manual compression test, which of course is another $240 on top of the $160 to tell me I had 4 injectors out. At first I told him to go ahead, but then said he could not do it right away so I ended up telling him to forget it. How would he conclude that there is something wrong in the bottom end by looking at the codes??? Injectors that are bad I believe he said was 2,3,5,and 8. Also a low ICP pressure code or something like that.
I think I might have found a better shop around here to look at it. A place called Midwest Diesel in Oak Grove Missouri.
I dont really know what to do now. I need this back up ASAP or a replacement
Any suggestions are greatly appreciated.
Oh yeah he also said it would be easily $4000 on the low side to replace the injectors. If that is what it is I believe I will be doing that myself. I would just like to know that is what it is for sure.
Thanks
Joe
Old 04-28-2010, 07:12 AM
caverjoe's Avatar
caverjoe
caverjoe is offline
For those that did not see my first thread it is titled Now Whats Wrong
Old 04-28-2010, 07:22 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Thanks
Joe
I dont know how far you are from Andrew (JKidd) but he has an AE and is very well versed in the woes of injectors. Brad (beanhead) is also close by also. Both are great guys and I am betting that they would be willing to help you out.
If 4 of them are out then it sounds like a harness or possibly an IDM issue.
I would get your truck out of there for starters. For what they are going to get you for diagnostics you can buy an AE and do it yourself.
Buy a new truck cause yours is ugly?????? Very nice professional comment. I would be making a phone call or two about that one.
Old 04-28-2010, 07:34 AM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
sounds more like there scaring you into a new truck..of course they know they can sell yours quickly for even more profit..
Old 04-28-2010, 07:41 AM
nhill2090
nhill2090 is offline
nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.
Jim I think he meant the results are ugly
Old 04-28-2010, 08:00 AM
bama29fan's Avatar
bama29fan
bama29fan is offline
bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.
my thoughts exactly....i hate not being able to trust people but it might just be something simple and cheap like Jim said and they are gonna rape you or scare you in to buying a new one and then selling yours for a handsome profit.
Old 04-28-2010, 08:17 AM
megawatt00's Avatar
megawatt00
I think your right . Note to self do not attempt to post prior to having coffee.......
Old 04-28-2010, 11:10 AM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is online now
DieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud of
$4000 for injectors? You can get a new crate motor for only slightly more from Clay or Ed!! I don't think it is a harness issue if those numbers are correct. Two on each bank. If they are really even bad...Dang.
Old 04-28-2010, 11:31 AM
nhill2090
labor at the stealerships is rediculous.
A novice drive way mechanic with an adjustable wrench and a hammer could change injectors faster than the time alloted on a dealers labor ticket.
Old 04-28-2010, 01:44 PM
Justin03PSD's Avatar
Justin03PSD
Justin03PSD is offline
Justin03PSD is gaining momentum as a positive member of FTE.
Thanks
Joe
Is the truck at Milner-O'Quinn in Harrisonville right now? I have used them before with good results, but I was very specific with my requests. Having anybody do diagnosis work gets expensive fast.
I am just up the road from you in Raymore. I don't have a lot of experience with my AE setup, but am willing to try and help with the diagnosis if you want.
I haven't heard about that shop in Oak Grove but it might be worth checking out. With the number of cylinders reporting problems I too would lean towards it being harness related.
Old 04-28-2010, 02:27 PM
aklim's Avatar
aklim
aklim is offline
aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.
Are they way more than the local rates or do they use different flat rate guides? My experience is that they use the same labor rate guide as most shops and their rates aren't that bad. I have seen independent shops charge a few bucks less per hour but they don't always have the tools. As such, they sometimes try to "make it up as they go along". One of those attempts resulted in many bent fins on my radiator of my car when they didn't have the proper tool to remove the fan clutch.
Old 04-28-2010, 03:21 PM
nhill2090
I have never taken my truck to the dealership under my ownership. Nor have I taken it to a shop, unless its getting aligned. So dont ask me. However I think dealers generally charge a greater hourly charge than most shops. And a good shop isnt out to swap parts until they find the solution and charge you $4000 in the process.
Or you can just do all your own work and save alot of headache and even more money.
Old 04-28-2010, 04:01 PM
aklim's Avatar
aklim
aklim is offline
My experience has been about $10 an hour different. IMO, the difference is that you have a "Jack of all trades" vs someone who specializes more in one type of vehicle. As to a parts swapper, I have seen them in BOTH dealerships and independents. I follow the tech. I had a tech at a dealership that was excellent and he moved to an independent shop and now he has gone into something else but will do side work.
Not always. I have been in some situations where I broke an expensive part or two and created even more headaches so it isn't always smooth sailing.
Old 04-28-2010, 04:04 PM
nhill2090
True, there are those cases.
And your right, broken parts are no fun. But as a diesel/heavy equipment tech, I do all my own work and then some on the side.
Old 04-28-2010, 04:41 PM
Action4478
Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Thanks
Joe
the search feature isn't kind to me lately, what are the symptoms?..I doubt it would drop 4, all at once.
Quick Reply: Stealership Results!!!!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
