A Couple of Quick Dash Fixes Needed
As I posted earlier today the new to me 2001 is home with me, however there are two annoying dash items that I want to remedy ASAP. One is the auxiliary 12V power source next to the airbag shut off doesn't appear to have juice.......any thoughts on the best way to fix that bugger?
Second, the black plate that surrounds the headlight switchgear comes out easily, as in when I pull out to put on the fogs I have to hold the plate in, can I just epoxy this thing? Is there a better fix?
So far everything else appears good........
Thanks a ton........
Steve
Steve
Check all your fuses with a test light for the plug.
I wouldn't epoxy the headlight switch in. Is the plate loose on the bottom or top? It has clips that make it snap into place. Pull the plate all the way out and let's figure out if it's something on the top or bottom that's broke and we'll try to figure out how to fix it.
On my 99 switch there are two red slide locking tabs that must be put in after the switch is installed. (think of it like a .50 mod would do for UVCH clips) If the slide tabs are not in there there is not enough outward force on the other tabs to hold the switch in the hole. since mine is a 99 it is only a three position switch (off, parking lights, and on) and a dimmer. So your switch may be different.
It might be the socket itself. I had to replace mine cuz the contacts were worn and broken beyond repair. I think i paid $12 for a replacement thru the dealer.
Yep, I agree
Mine too, at first I used light dabs of Super Glue, this allowed me to remove the cover for service if necessary without destroying it. I finally took the whole assembly out and fabricated the housing to fit my dimmer that came with my Isspro gauges. The small retaining nut on the dimmer switch now holds my cover on.
