Why is my turbo whistle fairly silent?
Old 04-27-2010, 04:40 PM
Joelong258's Avatar
Joelong258
Joelong258 is offline
Joelong258 is starting off with a positive reputation.
Ive seen lots of videos and see lots of trucks and it seems like everyones turbo is screaming except mine?
Why does it not do it loud?
And what can i do to make it louder (i love that sound)
Old 04-27-2010, 04:49 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
for the stock turbo the foil delete on the driver side IC pipe, a open air filter and the wicked wheel...or get the GTP38R..that's probably the video you are watching..
Old 04-27-2010, 04:57 PM
Joelong258's Avatar
Joelong258
ive been thinking of mods to do but also am on a very limited budget i was planning on a 6637 kit from clay next filter change.
I just looked up the wicked wheel and see its not too expensive i may look into one of those sometime..it would probably be a good idea anyways saying theres 200k on the stock turbo.
What is the purpose of the foil delete ive heard of it and tried to research it but didnt come up with much.
Old 04-27-2010, 05:18 PM
ron's power stroke
save this link some place safe..you will find 3 threads on this mod in there named "IC Pipe Foil Removal" down in the mod section..
Powerstroke Mods and Maintenance
the foil is like sound proofing on the pipe..with the early 99 trucks not having the foil..Ford found a lot of complaints that the whistle was too loud...that was one of the reasons..the other is it would keep heat from the manifolds out of the pipe ..we dont see that much of a diff...
Old 04-27-2010, 05:22 PM
Joelong258's Avatar
Joelong258
So how hard is the mod to complete?
And how long would it take?
Old 04-27-2010, 05:24 PM
ron's power stroke
couldnt tell ya..i have the early 99..never had the foil on it..but some say hard..some say not so hard..the link i posted will point you in the right direction...
Old 04-27-2010, 05:41 PM
Joelong258's Avatar
Joelong258
Ive been reading the forums from that link and it seems alot of people are using lots of wd40 and brake cleaner and wire wheels to remove the gunk left behind. I have access to a snapon sand blaster would that make the job easier or would it not work good at removing the glue?
Old 04-27-2010, 05:48 PM
Joelong258's Avatar
Joelong258
or even burn it off
Old 04-27-2010, 05:53 PM
ron's power stroke
I would stick to cleaning..there pretty thin aluminum pipes..but it is your truck..
Old 04-27-2010, 06:02 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
90% of them are steel pipes... There are a few aluminum ones out there, but there is no rhyme or reason to where they are.
Old 04-27-2010, 06:06 PM
Joelong258's Avatar
Joelong258
Thats where the magnet test comes in i suppose.
Old 04-27-2010, 06:07 PM
ron's power stroke
hmmmm i have a set on my truck..i have the aluminum cooler as well...built 3/98 maybe?? motor was built 1/98
Old 04-27-2010, 06:18 PM
Joelong258's Avatar
Joelong258
My truck was built in 6/99 so it was one of the last that rolled off the line
Old 04-27-2010, 06:20 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
Originally Posted by Joelong258 View Post
or even burn it off
That's what I did. Just took a plumbers torch and hit the glue for maybe 10 seconds till it turned black the scrapes right off with wire brush very easily.
Old 04-27-2010, 06:31 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
Like I said, its hit or miss... My wifes 2001 excursion has steel pipes and metal end tanks...
I have welded on countless IC pipes over the years...
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
