Water in fuel light! Help. Black smoke
Hello just got the water in fuel light at the same time as low fuel light. Got Diesel and filled it up and water in fuel light is still on. Can I drain the water out somehow? I am also have black smoke out the tailpipe and lack of power on accerlation sometimes. Could these be connected? Thanks
Well I do know the water in fuel light was a problem for a while. My 2005 had the issue. There was no water but it would come on. Needless to say Ford fixed it and it has never returned. If I ever saw that light, I wouldnt believe it. I have been told on this forum by many that it is VERY sensitive.
The water drain is on the horizontal fuel conditioning module (HFCM).
Park the truck with the front going up hill, stop the engine, and remove the fuel filler cap (gas cap). Using a 6mm Allen wrench remove the brass plug on the HFCM (aluminum looking thing mounted to the inside frame under the drivers seat). Let it drain and then replace the plug being sure not to over tighten it. It has an o-ring seal so just snug the plug. Perform 3 cycles of key on for 3 seconds then key off for 15 seconds to get any air out of the fuel system.
<O</O
For more info check out this link.
Service Points - HFCM and Fuel Filters
<O</O
https://www.ford-trucks.com/forums/8...lter-hfcm.html
Thanks but it's counter clockwise correct? 6mm allen?
I have tried twice and cannot get it to move. Granted it's an 03 and don't know if its ever been done. It's counterclockwise turn to left correct? If I strip it what is the next step to get it off or any tricks to getting the 6 mm allen to work. Not much room up there.
Thanks
Thanks
You will have to go to the dealer to get a new plug at least, the updated one is steel for that very reason, the brass would strip out. Did you strip the threads or the allen seat? If you stripped the threads you wanna run a tap of the same size through there b/f installing the new plug. If you stripped the allen seat you may want to use an easy out after getting a replacement plug. You really need to get the water out asap if there is some in there.
jc5.8literwindsor
09-16-2017 06:42 AM
GarrettTomaine
11-30-2015 10:34 PM
oubegood
1999 to 2016 Super Duty
07-02-2010 10:49 AM
