Just bought a 7.3 IDI
The Tach sending unit is dead.
Used this to test it.
dead tach sender on my 93 F-350 7.3 - Diesel Forum - TheDieselStop.com
PZ
PZ
So I read today the the injectors go bad slowly, and that they should be replaced about every 100k miles.
On my truck, I noticed that 6 of the injectors are painted the factory engine gray, and the other two are black. I also noticed that all the return lines are gray, except 1. This coupled with the two gray injectors I found IN the truck make me think that it has 6 original injectors, and an almost all original return system. This truck has about 160k on it. Should I be looking at replacing the injectors? Is there a way to tell if they are working 100%?
PZ
PZ
on
Not without a pop tester.
Injectors are ~$200 for a set.
It's best to replace them all at once.
If your truck starts fine after setting overnight there is nothing wrong with the return lines.
However, If you do replace the injectors it is also wise to use a Injector Installation Kit, in doing so you'll be replacing the return lines.
If the injectors are getting weak/worn, fuel mileage and performance decline.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
You suggest re-man, or new?
Found these
7.3 L Ford Diesel Fuel Injectors Fuel Pumps Accessories
They specify a year, and a code?
PZ
Found these
PZ
#30
