removing old smog stuff
Old Apr 25, 2010 | 10:11 PM
seafire's Avatar
seafire
A friend of mine bought a 78 F150 short box, with a 351M. He wants to take of the old smog lines. What lines need to be left on and what lines can be removed.
Thanks
Old Apr 25, 2010 | 10:19 PM
ubereal2's Avatar
ubereal2
Depending on your state regulations., removing things could fail a state motor vehicle inspection. I have a couple buddys, so it's all gone. No cat's, air pump, nodda....
Old Apr 25, 2010 | 10:45 PM
bamaf150's Avatar
bamaf150
Assuming there are no inspections to pass, then what can he remove? I posted the same question on the fe board and didnt get a response so I'm curious also.
Old Apr 26, 2010 | 09:14 AM
MadFrank81's Avatar
MadFrank81
I've been doing a lot of forum searches myself and came accross answers to your questions. It looks like if it's an egr-equipped engine then it really needs to have the egr itself still functioning as the engine is timed/tuned to expect that mix of gases, but other than egr I think the rest can go.
If it's a non-egr engine then it's much simpler, I think all you "have" to have hooked up is the vacuum advance and the choke pull-off, plug everything else!
Again, I'm no expert, this is just the jist of what I sort of picked up on. I'm sure someone else can give you specifics (and tell me I'm totally wrong )
Old Apr 26, 2010 | 12:08 PM
seafire's Avatar
seafire
smog
We live in Idaho, our town does not have any emission tests.
Old Apr 26, 2010 | 04:41 PM
jim collins's Avatar
jim collins
I live at the south end of idaho and we do have a couple of countys that test, but they are for 1980 or newer. I took all of it off of my 79, but I'm not sure if I need to hook the egr. back up or not. I'm going to try to get more information about it.
Old Apr 26, 2010 | 07:31 PM
fmc400's Avatar
fmc400
MSEE
I'm glad to see people are taking the time to research this the right way; kudos to you all.
Some helpful info: https://www.ford-trucks.com/forums/9...ml#post8773097
Old Apr 28, 2010 | 08:00 PM
baymurph's Avatar
baymurph
Similar issue
Having a vacuum leak from a (rusted out) valve? fitting? stem? located on rear driver's side just above the exhaust manifold. The line ran to some emission control stuff that looks like its been diconnected. Can't find a replacement. The stem is about 4 inches and looks flared at the end. Any idea what this is? Best solution?
Old Apr 29, 2010 | 10:38 AM
seafire's Avatar
seafire
missing piece
Is the missing piece coming from top of the exhaust manifold. If so, it was a heat tube for the carb.
Old Apr 29, 2010 | 11:16 PM
sweetlou's Avatar
sweetlou
me too
I have a 73 F100 do you guys know if I could take the smog line off. I don't have to have the beast tested anymore. thanks
Old Apr 30, 2010 | 12:06 AM
seafire's Avatar
seafire
smog
Take off the lines from the pump and intake manifold. Make sure that you have a line for vacum advance for the dizzy to the carb. If you an egr engine, left it alone.
Old Apr 30, 2010 | 08:35 AM
fmc400's Avatar
fmc400
MSEE
I have never personally heard of any problems with removing the smog pump (A.I.R. injection system) so long as you cap the vacuum port to the diverter valve. By the same token, though, I don't know of any problems with keeping it, unless there's some power loss by having your accessory drive run the smog pump (which I can't see as being much). On the other hand, it takes quite a bit of space and can get in the way.
I don't think a '73 would have a smog pump, though. A '73 could have EGR, though, and as seafire says it needs to stay. It's not a matter of having it tested, it's a matter of the way the engine is set up.
myoldf250
Jul 24, 2013 10:04 AM
diggintrenches
Aug 26, 2012 09:09 AM
abnjumpmaster
13
Jul 12, 2012 11:06 AM
ar1953
Jul 7, 2007 07:14 AM
montster
Oct 6, 2003 10:29 PM
