2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2011 Expedition HELP!!!
Old 08-27-2017, 11:12 AM
Brad Wissinger's Avatar
Brad Wissinger
Brad Wissinger is offline
Hey guys, so the wife's 2011 Expedition XLT is having some intermittent temperature issues. I say intermittent because there are days when she is driving it that the temperature gage on the dash stays in the middle (normal range). Other times (and it seems to be more common now) about 5-10 minutes of regular driving around town the temperature will spike high on the gage and remain high for the rest of the time.
So far I have noticed the level of the coolant reservoir slowly lower which I have topped off each time. I found a small leak from the tee fitting on a hose on the passenger side (not sure of hose number). I repaired the tee fitting and she drove it this morning. Within 5 minutes of her leaving the house she said it was hot again. A little while later (about 25 minutes or so) she said it was down (for now).
I've got a replacement thermostat to install today but I'm not sure if anyone else has had similar issues and knows the fix. I don't want to be start easter-egging this thing.
Old 08-31-2017, 09:28 PM
k9education's Avatar
k9education
k9education is offline
Repaired how? Has it stopped leaking? That is a high-pressure hose so it would be wise to replace it. I replaced that T and the other 2 heater hoses as well. I paid about $50 for all 3 from Rock Auto. As for the thermostat, I suggest a Stant SuperStat over the Motorcraft. The replacement Motorcraft tstat is complete garbage.
Old 09-01-2017, 09:50 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
You need to check the coolant temperature with a thermometer to verify the gauge or sender isn't bad. It's quite possible it's not overheating at all and the gauge is wrong.
whimsy
09-29-2016 09:39 PM
Rzr-runner1987
Modular V10 (6.8l)
02-11-2016 10:46 AM
timboleather
1999 to 2016 Super Duty
12-16-2009 08:07 PM
handyman43358
03-23-2008 02:37 PM
timbersteel
20
10-01-2007 05:28 PM
Quick Reply: 2011 Expedition HELP!!!
