Leaking around HPOP somewhere
I have replaced the HPOP, and HPOP gasket I even tried a new Ford gasket because the one that came with the HPOP was not OEM. I have the same leak as this guy.
https://youtu.be/lihdHZUVSxM
Does this look like a front cover leak? I am so deep into this truck whatever it is has to be fixed. Thanks guys
I've got the adrenaline and have a tiny leak into the valley. I couldn't find the leak until I looked under the hpop with a mirror and saw a allen head screw on the bottom of the hpop with a drip of oil hanging off of it. I cleaned it up and put a little JB weld on it and its slowed way down. I should take it off and send it to Dieselsite for repair.
Here is a youtube video of where my leak is coming from. starts leaking around 1:20 and this is with cold oil at an idle. It leaks much worse once it heats up and with higher RPM.
https://www.youtube.com/watch?v=3oLD...ature=youtu.be
Speck_d
01-11-2019 03:07 PM
Jeff W.
04-12-2015 02:08 PM
