If it has the three speed the pattern is reverse up, left, first is down left, second is up and to the right, third, down right. If it has the four speed first is up, left, second down, left, third up, center, forth down, center and reverse it down, to the right. With the four speed you start in second, first gear is very low and used only for pulling.
