1988 F150 EFI 5.0 won’t start
1988 F150 5.0 EFI - I used the truck 2 days ago and everything worked fine. Then yesterday I tried to start it and it cranked but wouldn’t start. I could hear the fuel pump spin up and I pulled a plug wire and was able to get a spark when I grounded the wire. I checked all the fuses and they were fine and I also checked the wiring for obvious issues. I tried starting it using starter fluid and got nothing. I don’t have a spark tester or fuel pressure tester.
I haven’t touched the motor in months. I rebuilt it years ago at 100k miles because a spark plug came apart in one of the cylinders. The truck now has 160k miles and the rebuild has always run great.
I assume the inertia switch and fuel pump relay are good because I can hear the fuel pump. I’m thinking that the ignition module or pick up magnet on the distributor may be the issue. How do I test them? Any other things I should check?
Thank you for the links. The first thing I did when the truck wouldn’t start was to look at the fuel gauge which showed 1/4 tank. I had my wife turn the key while I sprayed in starter fluid and this time the engine caught. Just to be sure I dumped in a couple of gallons of fuel into the tank and guess what….the truck started. My engine is fine, it’s my fuel gauge that is busted. At least that’s a bit easier to deal with. Thanks for the help.
The following users liked this post:
jessie forrest
11-05-2019 06:47 PM
Ronnie Locke
04-24-2013 08:48 PM
redfire-vert
03-14-2007 07:20 PM
Fully_Loaded
01-30-2005 10:23 PM
baldy9
10-25-2001 08:29 AM
