351w and C6 for 420ci and 4/5 speed auto..
so im gonna do a swamp from my 351 Windsor with a C6 4x4 trans to the 420 CI diesel with a 4 or 5 speed auto/ manual trans that hooks up to my transfer case..im gonna do this when i find a diesel motor from 1983 or newer that will fit in that gen truck..and im looking for a price range for everything and how hard will it be?? im gonna do all the work myself and a friend is gonna help..
So, what's the point? The 6.9 was a great motor, but it's not exactly a powerhouse and if ya wanna feel how sluggish your truck will be just pull two plug wires on that 351.
Don't get me wrong, my family has had two 1 tons with 6.9's and they both ended up having over half a million miles on them. But If I was spending the time and money to swap a motor in my truck the 6.9 would literally be last on the list. I'd put a 300 in before it. At the very least put a 7.3 in it.
well i need a power-train setup thats able to pull 5,000 lbs as i tow my friends car to the track alot..and his car is 3500+ lbs..(subaru STi) and i LOVE diesels i love the sound, the power, the MPG lol everything. i just needs to figure out what i need to make the diesel fit in my truck..i rather have an 83-90 motor..what ever i dont have to use an ECU one...IF thats possible...
It would be cheaper to get the whole truck. Then you can sell off what you don't need.
The diesel trucks with the heavy duty cooling(most have this) have a different radiator support for the extra large radiator.
They also have different motor mounts.
I believe the front frame crossmember might be a little different, but this might not be a deal breaker.
You will have some wiring to do for the glowplugs and a few other things, unless you have the other truck and get the wiring from it.
I'm not trying to criticize, just understand....
True, unloaded, my 7.3 had about the same acceleration as my other truck that had a 351w. Throw a full load of firewood in the back, and it was a different story. If you decide later to put a turbo on it, then you start really towing with some speed. As original though, the other poster is correct, even with a 5000 load, you will be a little slow going up the hills.
But as was mentioned also, I just like the diesel engine. The hardest part about it is getting it started, but once you learn all the ins and outs about that, it's a pretty good engine.
This is becoming a no brainer. You need to find a dually diesel donor. You can then hunt up the adapters to fit the dually wheels on the front 4wd axle.
