6G Alternator / ECM or no ECM? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 04-17-2010, 12:21 PM
gearloose1
gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
On a 2005 E Series with a 6.0 and a single alternator, can anyone tell me if it uses a 6G alternator with or without the ECM control?
Here are the two possibilities;
6G without ECM control from the Instrument Panel. (Grey and black regulator)
Other possibility:
6G with ECM control --- white regulator:
On my Grey D plug, there is a Light Green /Red stripe wire that with ignition on, tests with weak / low or no voltage.
The other wire (yellow?) is the Stator wire and it tests with good voltage.
Do I have a wire break in the Light Green / Red stripe wire?
Or do I have a defective ECM (if equipped)?
Old 04-17-2010, 12:53 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
This is for a 2004 F-250. I don't think a 2005 E series would be different. Single alternator does not involve the PCM. Dual alternator is different and does involve the PCM.
Old 04-17-2010, 06:03 PM
cheezit's Avatar
cheezit
cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
the grn/red wire should light up a low amp test light dimmly its just the sense circuit. I dont know if they ever corrected the book on that I know the book was a cut and paste at one point genric test.
Old 04-17-2010, 06:11 PM
dchamberlain
I was poking around my service manual and found this. It might help you with your problem.
FYI: I use ALLDATAdiy.com :: Leading Source of Diagnostic and Repair Information. It's about $26 for a 1 year subscription ($45 for 5 years) for the first vehicle, $17 ($30 for 5 years) for additional vehicles. It appears to be the actual Ford service manual that the tech's have. It has all the pinpoint tests, diagrams, exploded views, updated TSB's, etc, etc. It's pretty complete. I use it a lot.
Old 04-17-2010, 06:25 PM
cheezit's Avatar
cheezit
cheezit is offline
is that 8-9 volts back probed or at the connector face?
Old 04-17-2010, 06:32 PM
dchamberlain
It doesn't say. But I'm assuming it's back probed with the connector connected. If the connector was disconnected, then the A and B+ circuits, plus the battery, wouldn't be at 13-15 volts, because the alternator wouldn't be attempting to charge. They'd be at 12.5 or so.
I think.
Old 04-17-2010, 06:33 PM
cheezit's Avatar
cheezit
cheezit is offline
I think too.
Old 04-17-2010, 07:45 PM
gearloose1
dchamberlin, cheezit, bismic, and all the rest of you.
You just beat out my garage's tech... congratulations as always.
The Light Green / Red circuit, according to you, is suppose to test 1-3v with ignition on and engine not running....
I am going to go see him armed with that hot little bit of info.
Just to be sure, I am probably going to replace the Alternator pigtail --- as I believe that wiring is a notable point of failure.
Let me thank all of you for kindly helping me.... generously and graciously.... thanks thanks thanks..
You guys are the best!
Old 04-17-2010, 07:46 PM
cheezit's Avatar
cheezit
cheezit is offline
read your other post I covered the connector there
Old 07-08-2010, 02:15 AM
Fluid Power
Fluid Power is offline
Fluid Power is starting off with a positive reputation.
Just wondering where the fuse links physically are in a 2004 F350? (the links shown in the above drawing)
Old 07-08-2010, 04:20 PM
cheezit's Avatar
cheezit
cheezit is offline
the links are at the +battery lead at the right side battery afew incheh up from were it hooks on the positive end.
optikal illushun
44
01-03-2018 01:45 PM
ctubutis
'80-'86 HOWTO's
11-06-2016 12:09 AM
gearloose1
08-12-2016 06:22 PM
patclem
08-21-2015 10:39 PM
Quick Reply: 6G Alternator / ECM or no ECM?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
