long crank when cold
Old Apr 26, 2010 | 10:17 AM
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by billbot
thing is alternator may not be working very well. after a few minutes of engine on time, bats were only reading 13.38 volts. too low according to the dude at the battery shop. i think its supposed to be up around 14v. i'll look it up when i get a few mins.
Not necessarily. In addition to what npccpartsman said, your accessories are not at rated output when your are at idle. The batteries being low are a concern when you first start as they are a large amperage draw to charge. If you wanted to, you could remove all 4 battery cables after you start the truck and then take a DC voltage reading between one set (positive and negative) of cables to see what your voltage is. You should have low draw on the alternator so you can check voltage. Have somebody rev the engine a little to see if the voltage changes.
Batteries are rated at ~12VDC, so anything above that from the alternator and you are still charging the batteries, so 13.38VDC is still okay in my book.
Just my .02
Old Apr 26, 2010 | 12:08 PM
billbot's Avatar
billbot
Sounds good to me. Everything is working great now: bats fully charged, alt keeping them up, cranks over no problem, even had my truck washed for free this morning! (day off)
Now I can start to concentrate on some other things for the truck. Got an aux input for my ipod the other day. Next is gauges. I know it sounds like my priorities are off, but i am sick of listening to the garbage on the radio.
bigbeariron
Sep 24, 2020 07:49 PM
Number21
Jun 16, 2014 10:04 PM
ToddShroats
Jan 26, 2014 08:35 PM
Number21
Nov 4, 2013 10:09 AM
bigsnag
Nov 19, 2010 02:33 PM
