From gasoline to diesel. What to expect?
My wife wants my Expedition. That's good because I want a truck. I am considering purchasing a diesel F250, but have never had a diesel powered vehicle before. I'd appreciate some feedback from diesel owners on the advantages/disadvantages of diesel engines. Are they similar to gas engines for regular maintenance, etc? Tips?
I use it to occasionally pull a boat ~6500lbs and I drive about 20K miles/yr.
Thanks.
Thanks.
if you drive 20K miles a year and keep it for 10+ years a diesel will totally suit your bill.
-Diesel oil changes are more expensive, due to the massive amount of oil required 4+gallons
-You sig states you are in florida...so no problem with cold weather starting (although it's mostly a thing of the past)
- just remember...more towing power...means you are going to want a bigger boat....
Both of my trucks take something like 14 quarts. Oil changes cost more, so does the oil filter. You can usually go longer between oil changes with a diesel though. Both gas and diesel engines have their advantages and disadvantages. When you get right down to it, the main question is what do you want?
but unloaded the v-10 is a lot faster
but if you never tow above 7k any 250/350 is overkill
at the risk of someone taking after me with a pitchfork I'll point out that if you put 10-15k a yaer of that driving on a small car feul savings will more than make the car payment and you're truck will last longer
I agree, i went to the Ford dealership about 2 months ago to pick up some oil and filters for my 6.0, test drove some new f-150s, i immediatly knew i would never drive a gasser and be happy, i love diesels and wouldnt trade down to a gas for anything
