Progress Pics on my 55 F100
Thanks, but I can take credit for the welding, Bob at Dukes Speedmaster in Houston gets all that credit. I diden't feel safe doing that kind of work myself and left it to the experts.
I thought I would post a few update pictures of my truck. Its been a while, and it seems slow going, but it is starting to look like it may actually get done some day now.
Motor is done now. It is a 64 289 (now 306) with a few upgrades
The small block Ford pulled a honest 348 on the dyno
Trial fitted the cab. Looking like a truck again!
Time to cut up the two cabs apart and put them back together as one.
Basically we removed the top from a new cab and installed it on to the original truck's floor, which thanks to a lot of undercoating, was basically in really good shape.
After bracing everything up, we sodablasted the cab. Already looking better.
You can see some of the rust in the top cab, as we carefully removed the it's floor
Floor is removed
Floor is removed
Time now to work on the floor...
Patch panels were added to the corners including new cab mounts, upper cap and plates, and lower retainers from Mid Fifty.
We cut out just what we need from the floor pan patch panels
All nicely welded up
Inner Corners going in
Floor is done! Now will this all fit together....... I think so, since this looks to be the way Ford assembled these cabs the first time.
